[Qgis-developer] Is it possible to re-use print composer code to
build a web service ?
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Tue Dec 21 03:32:28 EST 2010
Hi Allesandro
> Did you foresee the possibility to insert kvp substitution parameters for
> text strings in print templates ?
Yes, the possibility to replace label text (as well as extent, rotation,
layers for composer maps) is planned.
Regards,
Marco
Am Dienstag, 21. Dezember 2010, um 09.08:48 schrieb Alessandro Pasotti:
> 2010/12/20 Andreas Neumann <a.neumann at carto.net>
> > Hi Allesandro,
> > In fact, Marco is currently working on exactly what you want. He is
> > extending QGIS mapserver with a GetPrint command that allows to specify
> > the map extent, the layout/template to use, rotation parameter, dpi,
> > etc. and you'll get a PDF/SVG/PNG/JPEG as output. The templates will be
> > picked up from the QGIS project file.
> > If you can wait until next year (probably mid to end of January) it will
> > be part of QGIS mapserver.
> > So no need to work on it in parallel - unless you have something else in
> > mind.
> Great!
> This is exactly what I had in mind, so I will wait for your solution.
> Something that allows sending substitution strings in the request, for
> example the name of the customer or similar short text snippets.
> example:
> [ Printed by: {username}]
> Thanks a lot for this developments!
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Churerstr. 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
