[Qgis-developer] google layers plugin
Ivan Mincik
ivan.mincik at gista.sk
Tue Dec 21 06:09:42 EST 2010
> How to display google maps for my own shapefile.
> For my shapefile google map is not displaying. But google layers plugin
> works for the shapefile comes with the plugin source code
When You configure correctly Google Mercator for You project and enable
'on the fly reprojection', You must configure correct projection for
Your vector data. After this is done, everything will be correctly aligned.
I think, You have incorrect projection for Your data.
Ivan Mincik, Gista s.r.o.
