[Qgis-developer] Native SQL Anywhere plugin+provider contributed
to trunk
Tim Sutton
lists at linfiniti.com
Wed Dec 22 15:13:49 EST 2010
Hi (taking this back on list as others will benifit from your
responses if they read the archives)
On Wed, Dec 22, 2010 at 10:00 PM, <Dave.DeHaan at sybase.com> wrote:
> Hi Tim,
> As you discovered, you only need to specify ServerName if you are trying to
> distinguish between multiple database servers; otherwise the connection
> goes to the "default" server, which is the first one that was started on
> the host.
> http://dcx.sybase.com/index.html#1200en/dbadmin/da-conparm.html
> In the connection setup dialog for the plugin, I've tried to use the
> context-help to indicate when a parameter is optional ("leave blank for
> default server on host").
Thanks - yes I discovered the context help when setting up the QGIS
SQL Anywhere provider connection. I am up and running now thanks. As
initial feedback (after playing with it for 10 mins) is that it seems
to run without problems and do what it says on the box. The only
hiccup I have encountered so far is that the sql loader script for
Alaska data does not seem to run cleanly. I removed some of the shp
layer names from the initial list as I only have alaska, lakes and
majrivers here on my local setup. When the script ran, it dropped the
tables based on layer names ok but trying to load the shapefiles it
would report something like:
Failed to load '/home/timlinux/gisdata/Alaska/.shp'
i.e. it was not properly concatenating in the layernams for the shp
loader part of the script.
Since I was eager just to see a pretty picture, I shamelessly cheated
to get the alaska boundary and then a local EPSG:4326 based dataset to
load by simply calling:
CALL load_shapefile( '/home/timlinux/gisdata/Alaska/alaska.shp',
1000002964, 'QGIS_alaska' );
'/home/timlinux/gisdata/Africa/Jozi/2628-Vector-WGS84/2628_ROAD_LINE_2006_12.shp',
1000004326, 'QGIS_jozi_roads' );
It would be interesting to run some benchmarks comparing SQL Anywhere
with SpatialLite and PostgreSQL/PostGIS. If I have some time I will do
some simple tests of that nature.
Thanks for the contribution! No doubt you will start getting a trickle
of queries as more people start to explore the new goodies :-)
Regards
Tim
> Let me know if you encounter anything that needs clarification.
> Best regards,
> Dave
> David E. DeHaan
> Query Processing team
> Sybase iAnywhere
> From: Tim Sutton <lists at linfiniti.com>
> To: <Dave.DeHaan at sybase.com>
> Cc: <qgis-developer at lists.osgeo.org>
> Date: 12/22/2010 02:18 PM
> Subject: Re: [Qgis-developer] Native SQL Anywhere plugin+provider contributed to trunk
> Hi again
> On Wed, Dec 22, 2010 at 9:10 PM, Tim Sutton <lists at linfiniti.com> wrote:
>> Hi Dave
>> Just getting around to test driving the new provider.
>> What is the correct value for 'servername' in the dbisql gui (assuming
>> having followed your instructions below and that the database I
>> created is called 'gis').
> Ok I came right by doing 'start and connect', and then leaving the
> servername blank.
> Regards
> Tim
>> Thanks
>> Tim
>> On Thu, Dec 16, 2010 at 12:00 AM, <Dave.DeHaan at sybase.com> wrote:
>>> Hello QGIS Devs,
>>> As per discussion on qgis-psc a couple of weeks ago, I have just
>>> contributed (rev. 14918) a native plugin+provider for Sybase SQL
> Anywhere
>>> (trunk/qgis/src/plugins/sqlanywhere;
> trunk/qgis/src/providers/sqlanywhere),
>>> similar in functionality to the PostGIS and SpatiaLite providers. Due
> to a
>>> legal technicality, this code needed to be released under GPL v3 rather
>>> than the usual GPL v2 used by the rest of the QGIS project.
>>> I've tested the code under both Ubuntu 10.04 (gcc) and Windows XP (MSVC
>>> 2008). If there are developers out there on other platforms, could you
>>> please let me know if the plugin fails to either compile or load on your
>>> platform (loading it should add a toolbar button and a couple menu
>>> options)?
>>> If anyone is interested in taking the plugin/provider for a test drive,
>>> here is a quick set of steps to get you started:
>>> 1. Download the free Developer's Edition of SQL Anywhere 12.0.0 here:
>>> http://www.sybase.com/detail?id=1016644
>>> 2. Install the SQL Anywhere 12.0.0 engine on your database host
>>> 3. Install the SQL Anywhere 12.0.0 client libraries on your QGIS client
>>> (only necessary if client and host are different machines)
>>> 4. Use 'dbinit my_database_name' to initialize a blank database on the
>>> host. The default user/password is initialized to 'dba'/'sql'.
>>> 5. Use 'dbsrv12 my_database_name' to start the database server on the
>>> host.
>>> 6. Populate the database with sample spatial data. To facilitate this
>>> step, I have contributed the SQL script
>>> src/providers/sqlanywhere/load_alaska_shapes.sql which loads the Alaska
>>> VMap0 shapefiles into new tables. Use the 'Interactive SQL' tool
> (dbisql)
>>> on the database host to open/execute this script (you will need to
> modify a
>>> few variables at the top of the script to tell it where to find the
>>> shapefiles, which are assumed to be on the filesystem of the database
>>> host).
>>> 7. Start up QGIS, and load the SQL Anywhere plugin. This will add a
>>> button to the data sources toolbar, as well as the menu entries
> 'Plugins->
>>> SQL Anywhere' and 'Layer->Add SQL Anywhere Layer...'
>>> 8. Adding a SQL Anywhere layer should invoke a dialogue box for
> choosing
>>> a connection and searching the database schema for geometry columns
>>> (similar look/feel/functionality to the PostGIS and SpatiaLite toolbar
>>> buttons). If you instead receive a message box, it means that it can't
>>> find the SQL Anywhere client libraries installed in step 3 (or step 2 if
>>> client=host).
>>> Please let me know if you have any
> questions/comments/suggestions/bugs...
>>> Thanks,
>>> Dave
>>> David DeHaan
>>> SQL Anywhere Research and Development
>>> Sybase iAnywhere
>>> ddehaan at sybase.com
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Visit http://linfiniti.com to find out about:
>> * QGIS programming and support services
>> * Mapserver and PostGIS based hosting plans
>> * FOSS Consulting Services
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
> Skype: timlinux
Skype: timlinux
