[Qgis-developer] Native SQL Anywhere plugin+provider contributed to trunk
Tim Sutton lists at linfiniti.com
Wed Dec 22 15:37:09 EST 2010
Hi Again
------8<-----snip-------------
> Thanks for the contribution! No doubt you will start getting a trickle
> of queries as more people start to explore the new goodies :-)
One more thing I wanted to add - it would be great to have an easier
way to load shp or other format data into the database. Most folks
will be used to loading data with SPOT/shp2pgsql/ogr2ogr or similar
high level tools. While your provided script is not hard to use, it
will lower the entry bar that much more to provide a similar mechanism
for SQL Anywhere.
Best regards
Tim
> Regards
> Tim
>> Let me know if you encounter anything that needs clarification.
>> Best regards,
>> Dave
>> David E. DeHaan
>> Query Processing team
>> Sybase iAnywhere
>>  From:       Tim Sutton <lists at linfiniti.com>
>>  To:         <Dave.DeHaan at sybase.com>
>>  Cc:         <qgis-developer at lists.osgeo.org>
>>  Date:       12/22/2010 02:18 PM
>>  Subject:    Re: [Qgis-developer] Native SQL Anywhere plugin+provider contributed to trunk
>> Hi again
>> On Wed, Dec 22, 2010 at 9:10 PM, Tim Sutton <lists at linfiniti.com> wrote:
>>> Hi Dave
>>> Just getting around to test driving the new provider.
>>> What is the correct value for 'servername' in the dbisql gui (assuming
>>> having followed your instructions below and that the database I
>>> created is called 'gis').
>> Ok I came right by doing 'start and connect', and then leaving the
>> servername blank.
>> Regards
>> Tim
>>> Thanks
>>> Tim
>>> On Thu, Dec 16, 2010 at 12:00 AM,  <Dave.DeHaan at sybase.com> wrote:
>>>> Hello QGIS Devs,
>>>> As per discussion on qgis-psc a couple of weeks ago, I have just
>>>> contributed (rev. 14918) a native plugin+provider for Sybase SQL
>> Anywhere
>>>> (trunk/qgis/src/plugins/sqlanywhere;
>> trunk/qgis/src/providers/sqlanywhere),
>>>> similar in functionality to the PostGIS and SpatiaLite providers.  Due
>> to a
>>>> legal technicality, this code needed to be released under GPL v3 rather
>>>> than the usual GPL v2 used by the rest of the QGIS project.
>>>> I've tested the code under both Ubuntu 10.04 (gcc) and Windows XP (MSVC
>>>> 2008).  If there are developers out there on other platforms, could you
>>>> please let me know if the plugin fails to either compile or load on your
>>>> platform (loading it should add a toolbar button and a couple menu
>>>> options)?
>>>> If anyone is interested in taking the plugin/provider for a test drive,
>>>> here is a quick set of steps to get you started:
>>>>  1. Download the free Developer's Edition of SQL Anywhere 12.0.0 here:
>>>> http://www.sybase.com/detail?id=1016644
>>>>  2. Install the SQL Anywhere 12.0.0 engine on your database host
>>>>  3. Install the SQL Anywhere 12.0.0 client libraries on your QGIS client
>>>> (only necessary if client and host are different machines)
>>>>  4. Use 'dbinit my_database_name' to initialize a blank database on the
>>>> host.  The default user/password is initialized to 'dba'/'sql'.
>>>>  5. Use 'dbsrv12 my_database_name' to start the database server on the
>>>> host.
>>>>  6. Populate the database with sample spatial data.  To facilitate this
>>>> step, I have contributed the SQL script
>>>> src/providers/sqlanywhere/load_alaska_shapes.sql which loads the Alaska
>>>> VMap0 shapefiles into new tables.  Use the 'Interactive SQL' tool
>> (dbisql)
>>>> on the database host to open/execute this script (you will need to
>> modify a
>>>> few variables at the top of the script to tell it where to find the
>>>> shapefiles, which are assumed to be on the filesystem of the database
>>>> host).
>>>>  7. Start up QGIS, and load the SQL Anywhere plugin.  This will add a
>>>> button to the data sources toolbar, as well as the menu entries
>> 'Plugins->
>>>> SQL Anywhere' and 'Layer->Add SQL Anywhere Layer...'
>>>>  8. Adding a SQL Anywhere layer should invoke a dialogue box for
>> choosing
>>>> a connection and searching the database schema for geometry columns
>>>> (similar look/feel/functionality to the PostGIS and SpatiaLite toolbar
>>>> buttons).  If you instead receive a message box, it means that it can't
>>>> find the SQL Anywhere client libraries installed in step 3 (or step 2 if
>>>> client=host).
>>>> Please let me know if you have any
>> questions/comments/suggestions/bugs...
>>>> Thanks,
>>>> Dave
>>>> David DeHaan
>>>> SQL Anywhere Research and Development
>>>> Sybase iAnywhere
>>>> ddehaan at sybase.com
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
>>> Please do not email me off-list with technical
>>> support questions. Using the lists will gain
>>> more exposure for your issues and the knowledge
>>> surrounding your issue will be shared with all.
>>> Visit http://linfiniti.com to find out about:
>>>  * QGIS programming and support services
>>>  * Mapserver and PostGIS based hosting plans
>>>  * FOSS Consulting Services
>>> Skype: timlinux
>>> Irc: timlinux on #qgis at freenode.net
>> Skype: timlinux
> Skype: timlinux
Skype: timlinux
