[Qgis-developer] set plugin enabled by default
Giovanni Manghi
giovanni.manghi at gmail.com
Sun Feb 28 15:14:33 EST 2010
as far as I can see since qgis 1.4 python plugins are immediately
activated after installation.
cheers
-- Giovanni --
On Fri, 2010-02-26 at 19:48 +0100, Stefan Kiefer wrote:
> Hi there,
> does someone knows if there is a way to set a plugin enabled by default.
> My trouble is: when the Plugin gets installed it should be visible to
> the user after startup of Qgis. The user should not be forced to open
> the plugs menu and search for the plugin and activate it.
> Is there any way to perform this, probably by modifying the default
> plugins (ftools or plugin_installer). It must work for standard Qgis
> installations, without changing the source code (modifying the python
> code is also not what I really need, but could be a workaround).
> Maybe there is a possibility to get the installed plugins and activate
> the one needed?
> thanks for your help
> cheers
> Stefan
> Qgis-developer mailing list
