[Qgis-developer] (very) dynamic (python) forms
Richard Duivenvoorde
rdmailings at duif.net
Mon Jan 4 08:12:20 EST 2010
Hi Andreas,
I'm very much interested in it. Can you sent it to me?
Regards,
Richard
Andreas Neumann wrote:
> Hi Richard,
> In the QGIS 1.4 or the development builds there is the possibility to
> specify an onload python script. This script is called whenever the
> dialogue is opened.
> I can send you an example tomorrow and more info from my workplace. I
> don't have it at home. Jürgen Fischer implemented this if you have more
> in-depth questions.
> Best,
> Andreas
> On Sun, January 3, 2010 1:02 pm, Richard Duivenvoorde wrote:
>> Hi List,
>> I got a question from some fieldworkers to be able to do (point/area)
>> digitizing in the field using qgis and qps on a netbook with touchscreen.
>> I read tim's blog post:
>> http://linfiniti.com/2009/11/creating-dynamic-forms-a-new-feature-headed-for-qgis-1-4/
>> I need a way to hook my own dialog into the edittool, but only using the
>> ui-file is not enough, because I need to fill/layout the dialog with
>> dropdowns according to a certain context.
>> Any ideas, pointers or lines of code to be able to use a truly dynamic
>> scriptable form?
>> For example: where do I hook a python plugin into the edittool(s)?
>> Did other people already do a project like this?
>> Regards,
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
