[Qgis-developer] Re: AW: Re: AW: Re: [Qgis-user] CAD functions
plugin
Paolo Cavallini
cavallini at faunalia.it
Fri Jan 8 04:13:06 EST 2010
Ziegler Stefan ha scritto:
> Hi Paolo
>> Here you are:
>> http://pyqgis.org/
>> Perhaps this should be documented more clearly?
> Thanks. Just uploaded the plugin. Is there a reason that you can only
> choose between 1.0 and 1.1 as minimum version? I only tested the plugin
> against 1.3.
Hi.
This should be updated: who can do it?
Can someone document how to add a plugin to standard repos? This is not the first
time people waste time setting up their own repo, just because they ignore how to add
their plugin to the standard repo.
All the best, and thanks a lot.
Paolo Cavallini: http://www.faunalia.it/pc
