[Qgis-developer] Re: SVGFill test
John C. Tull
jctull at gmail.com
Sat Jan 16 15:35:36 EST 2010
Hi Marco,
It seems to not work on shapefiles, postgis, etc. Here is a test shapefile anyway. I used several standard svg symbols from the default selection, none of which worked. Perhaps I did not try enough. The red and blue asterisk thing is one. Here's one of my own that did not work also.
Thanks,
John
On Jan 16, 2010, at 11:42 AM, Marco Hugentobler wrote:
> Hi John
> Could you send me the svg file you used and a small test dataset where the
> problem happens? Like that, I could check if it works on my system or not.
> The svg files I tested so far worked (but not all 100% correct, probably
> because of the Qt SVG classes).
> Regards,
> Marco
> Am Samstag, 16. Januar 2010 19.25:54 schrieb John C. Tull:
>> Hi Marco,
>> I am quite interested in the progress you are making with the composer. I
>> tested the newly added svgfill a moment ago on my OS X system.
>> Unfortunately, despite changing the outline color to yellow and providing
>> an svg symbol for the fill, the layer remains unfilled and with a black
>> outline. I tested this on my ubuntu vm also, and no luck there either. I
>> am guessing this is a work in progress and I may be jumping the gun.
>> Otherwise, I must be doing something incorrectly or it is broken.
>> Cheers,
>> John
> Dr. Marco Hugentobler
> HUGIS - GIS programming and consulting
> Webereistr. 66
> CH-8134 Adliswil
> marco at hugis.net
> http://homepage.hispeed.ch/hugis/
> Technical Advisor QGIS Project Steering Committee
Type: application/zip
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100116/86a36a9c/test_shp.zip
Type: image/svg+xml
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100116/86a36a9c/butterfly_blue.bin
