[Qgis-developer] Re: SVGFill test
Marco Hugentobler
marco at hugis.net
Sat Jan 16 16:03:29 EST 2010
Hi John
Hm, it works for me here (kubuntu 9.10).
See screenshot
www.hugis.net/svgfill.png
Maybe a problem only on Mac?
Regards,
Marco
Am Samstag, 16. Januar 2010 21.35:36 schrieb John C. Tull:
> Hi Marco,
> It seems to not work on shapefiles, postgis, etc. Here is a test shapefile
> anyway. I used several standard svg symbols from the default selection,
> none of which worked. Perhaps I did not try enough. The red and blue
> asterisk thing is one. Here's one of my own that did not work also.
> Thanks,
> John
> On Jan 16, 2010, at 11:42 AM, Marco Hugentobler wrote:
> > Hi John
> > Could you send me the svg file you used and a small test dataset where
> > the problem happens? Like that, I could check if it works on my system or
> > not.
> > The svg files I tested so far worked (but not all 100% correct, probably
> > because of the Qt SVG classes).
> > Regards,
> > Marco
> > Am Samstag, 16. Januar 2010 19.25:54 schrieb John C. Tull:
> >> Hi Marco,
> >> I am quite interested in the progress you are making with the composer.
> >> I tested the newly added svgfill a moment ago on my OS X system.
> >> Unfortunately, despite changing the outline color to yellow and
> >> providing an svg symbol for the fill, the layer remains unfilled and
> >> with a black outline. I tested this on my ubuntu vm also, and no luck
> >> there either. I am guessing this is a work in progress and I may be
> >> jumping the gun. Otherwise, I must be doing something incorrectly or it
> >> is broken.
> >> Cheers,
> >> John
Dr. Marco Hugentobler
HUGIS - GIS programming and consulting
Webereistr. 66
CH-8134 Adliswil
marco at hugis.net
http://homepage.hispeed.ch/hugis/
Technical Advisor QGIS Project Steering Committee
