[Qgis-developer] Xcode build problems
William Kyngesburye
woklist at kyngchaos.com
Sat Jan 16 19:15:29 EST 2010
Good catch.
On Jan 16, 2010, at 6:06 PM, John C. Tull wrote:
> Thanks for explaining that. It is building now. Note that the configure command is inside the configure directory, a detail that probably should also be added to the instructions.
> On Jan 16, 2010, at 3:49 PM, William Kyngesburye wrote:
>> On Jan 16, 2010, at 5:28 PM, John C. Tull wrote:
>>> William,
>>> Under the pyqwt build step, are you to cd into the configure directory within the pyqwt source? This part is unclear, and I am getting an error trying that with your configure statement.
>>> sh: /bin/qmake: No such file or directory
>>> make: qwt_version_info.mak: No such file or directory
>>> make: *** No rule to make target `qwt_version_info.mak'. Stop.
>>> sh: qwt_version_info.app/Contents/MacOS/qwt_version_info: No such file or directory
>>> Failed to import qwt_version_info.
>> Ah, there is a detail in the PyQt build that up to now wasn't important, but it is for PyQwt. I'm not sure if it's a PyQt bug or not, or maybe a glitch in Qt if PyQt gets this setting from Qt. After configuring PyQt, edit pyqtconfig.py and change the qt_dir line to:
>> 'qt_dir': '/usr',
>> then make and install. You can fix an already-installed PyQt by editing the installed pyqtconfig.py.
>> Then the PyQwt configure will work. I'll update INSTALL with this.
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "I ache, therefore I am. Or in my case - I am, therefore I ache."
>> - Marvin
> Qgis-developer mailing list
"Oh, look, I seem to have fallen down a deep, dark hole. Now what does that remind me of? Ah, yes - life."
- Marvin
