[Qgis-developer] Xcode build problems
John C. Tull john.tull at wildnevada.org
Sat Jan 16 19:06:16 EST 2010
Thanks for explaining that. It is building now. Note that the configure command is inside the configure directory, a detail that probably should also be added to the instructions.
On Jan 16, 2010, at 3:49 PM, William Kyngesburye wrote:
> On Jan 16, 2010, at 5:28 PM, John C. Tull wrote:
>> William,
>> Under the pyqwt build step, are you to cd into the configure directory within the pyqwt source? This part is unclear, and I am getting an error trying that with your configure statement.
>> sh: /bin/qmake: No such file or directory
>> make: qwt_version_info.mak: No such file or directory
>> make: *** No rule to make target `qwt_version_info.mak'.  Stop.
>> sh: qwt_version_info.app/Contents/MacOS/qwt_version_info: No such file or directory
>> Failed to import qwt_version_info.
> Ah, there is a detail in the PyQt build that up to now wasn't important, but it is for PyQwt.  I'm not sure if it's a PyQt bug or not, or maybe a glitch in Qt if PyQt gets this setting from Qt.  After configuring PyQt, edit pyqtconfig.py and change the qt_dir line to:
> 'qt_dir': '/usr',
> then make and install.  You can fix an already-installed PyQt by editing the installed pyqtconfig.py.
> Then the PyQwt configure will work.  I'll update INSTALL with this.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "I ache, therefore I am.  Or in my case - I am, therefore I ache."
> - Marvin
