[Qgis-developer] sip compile error
Germán Carrillo carrillo.german at gmail.com
Tue Jan 26 14:20:52 EST 2010
Hi Martin,
Currently the imports from PyQt4 and qgis.core are returning the *Segmentation
fault*. :(
Thank you.
German
El 25 de enero de 2010 16:59, Martin Dobias <wonder.sk at gmail.com> escribió:
> 2010/1/25 Germán Carrillo <carrillo.german at gmail.com>:
> > Hi all.
> > I have the same trouble, I can't even use QGIS from binary packages after
> > compiling SIP 4.10. Riverbank seems to delete previous SIP releases from
> the
> > servers. Altough I did also compile PyQT 4.7 trying to fix it.
> > I'm using Ubuntu Jaunty (9.04) and I get a Segmentation fault if I want
> to
> > use PyQGIS.
> > I don't know if there is a correct combination of Qt, PyQt, Python and
> SIP
> > versions.
> There might be additional packages dependent on SIP/PyQt that might
> need recompilation when upgrading SIP/PyQt - python bindings for Qwt
> or QScintilla may cause the havoc. Start python interpreter and do
> various imports (sip, PyQt4, qgis.core) to find out which part of the
> chain is broken.
> Anyway I'll try to fix the compilation for sip 4.7.
> Martin
  |\__
(:>__)(
Soluciones Geoinformáticas Libres
http://geotux.tuxfamily.org/
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100126/aa13ed93/attachment.html
