[Qgis-developer] WMS tileset support
Noli Sicad nsicad at gmail.com
Fri Jul 16 22:05:19 EDT 2010
Correction.
GeoWebCache as the map tile server.
Noli
On 7/17/10, Noli Sicad <nsicad at gmail.com> wrote:
> Hi Jeremy,
> I think GeoStack has this function - Map tile server
> "The “geostack” consists of the following functional parts:
> Map tile server that can store pre-rendered map tiles and serve them
> up quickly to make maps seems to draw faster. Examples include ArcGIS
> Server, MapGuide, Tilecache, GeoWebCache"
> http://workshops.opengeo.org/stack-intro/introduction.html
> Noli
> On 7/17/10, Jeremy Palmer <JPalmer at linz.govt.nz> wrote:
>> I'm trialling the use of Geoserver for serving up images to QGIS clients.
>> I
>> can get WMS to work well. However I was wondering about the QGIS support
>> for
>> tile sets. As far as I can see in the QGIS WMS proveder source code, tile
>> sets are supported if there is a VendorSpecificCapabilities/TileSet tag
>> in
>> the get capability request.
>> Does any know if you can get Geoserver (or any other open source web
>> mapping
>> service) to provider this capability?
>> Thanks,
>> Jeremy Palmer
>> Geodetic Surveyor
>> National Geodetic Office
>> Land Information New Zealand | Toitu te whenua
>> 160 Lambton Quay | Private Box 5501 | Wellington 6145
>> DDI: 64 (0)4 498 3537 | Fax: 64 (0)4 498 3837 |
>> www.linz.govt.nz<http://www.linz.govt.nz>
>> ______________________________________________________________________________________________________
>> This message contains information, which is confidential and may be
>> subject
>> to legal privilege.
>> If you are not the intended recipient, you must not peruse, use,
>> disseminate, distribute or copy this message.
>> If you have received this message in error, please notify us immediately
>> (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original
>> message.
>> LINZ accepts no responsibility for changes to this email, or for any
>> attachments, after its transmission from LINZ.
>> Thank you.
