[Qgis-developer] WMS tileset support
    Jeremy Palmer
    JPalmer at linz.govt.nz
    Fri Jul 16 22:13:10 EDT 2010
Ok thanks. I looked at Geoserver's built in GWC, but I couldn't seem to get QGIS to work with it. I tried these URLs:
http://localhost:8080/geoserver/gwc/service/wmts?REQUEST=getcapabilities
http://localhost:8080/geoserver/gwc/service/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=getcapabilities&TILED=true
and neither of them had the VendorSpecificCapabilities/TileSet tag.
I also tried the TMS service Capabilities but I could get that working:
http://localhost:8080/geoserver/gwc/service/tms/1.0.0
it gave an error saying "Unknown layer 1.0.0. Check the logfiles, it may not have loaded properly".
If it's the TMS service I need for tile set support in QGIS then I may need to follow this up with either the Geoserver or the GWC guys, because I don't understand what is wrong here.
Cheers,
Jeremy
-----Original Message-----
Sent: Saturday, 17 July 2010 2:05 p.m.
To: Jeremy Palmer
Cc: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] WMS tileset support
Correction.
GeoWebCache as the map tile server.
Noli
On 7/17/10, Noli Sicad <nsicad at gmail.com> wrote:
> Hi Jeremy,
> I think GeoStack has this function - Map tile server
> "The "geostack" consists of the following functional parts:
> Map tile server that can store pre-rendered map tiles and serve them
> up quickly to make maps seems to draw faster. Examples include ArcGIS
> Server, MapGuide, Tilecache, GeoWebCache"
> http://workshops.opengeo.org/stack-intro/introduction.html
> Noli
> On 7/17/10, Jeremy Palmer <JPalmer at linz.govt.nz> wrote:
>> I'm trialling the use of Geoserver for serving up images to QGIS clients.
>> I
>> can get WMS to work well. However I was wondering about the QGIS support
>> for
>> tile sets. As far as I can see in the QGIS WMS proveder source code, tile
>> sets are supported if there is a VendorSpecificCapabilities/TileSet tag
>> in
>> the get capability request.
>> Does any know if you can get Geoserver (or any other open source web
>> mapping
>> service) to provider this capability?
>> Thanks,
>> Jeremy Palmer
>> Geodetic Surveyor
>> National Geodetic Office
>> Land Information New Zealand | Toitu te whenua
>> 160 Lambton Quay | Private Box 5501 | Wellington 6145
>> DDI: 64 (0)4 498 3537 | Fax: 64 (0)4 498 3837 |
>> www.linz.govt.nz<http://www.linz.govt.nz>
>> ______________________________________________________________________________________________________
>> This message contains information, which is confidential and may be
>> subject
>> to legal privilege.
>> If you are not the intended recipient, you must not peruse, use,
>> disseminate, distribute or copy this message.
>> If you have received this message in error, please notify us immediately
>> (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original
>> message.
>> LINZ accepts no responsibility for changes to this email, or for any
>> attachments, after its transmission from LINZ.
>> Thank you.
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
