[Qgis-developer] WMS tileset support
Noli Sicad
nsicad at gmail.com
Fri Jul 16 22:41:31 EDT 2010
Reading again, this page
http://www.qgis.org/en/developer-meetings/pisa-2010.html
I think Tile Cache Support in QGIS is fully supported!
My bad.
Noli
On 7/17/10, Noli Sicad <nsicad at gmail.com> wrote:
> I think Tile Cache Support in QGIS is not yet fully implemented
> See this summer of code.
> http://www.qgis.org/wiki/Google_Summer_of_Code_2010#Tile_Cache_Support
> It is meeting in this Third QGIS Hackfest in Pisa 2010 ---support for
> WMS-C tilesets,
> 22 Mar 2010 ... Added WMS-C support to WMS provider, support for
> WMS-C tilesets, several WMS selection improvements. Improved
> SOS-Plugin and extended ...
> Noli
> On 7/17/10, Jeremy Palmer <JPalmer at linz.govt.nz> wrote:
>> Ok thanks. I looked at Geoserver's built in GWC, but I couldn't seem to
>> get
>> QGIS to work with it. I tried these URLs:
>> http://localhost:8080/geoserver/gwc/service/wmts?REQUEST=getcapabilities
>> http://localhost:8080/geoserver/gwc/service/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=getcapabilities&TILED=true
>> and neither of them had the VendorSpecificCapabilities/TileSet tag.
>> I also tried the TMS service Capabilities but I could get that working:
>> http://localhost:8080/geoserver/gwc/service/tms/1.0.0
>> it gave an error saying "Unknown layer 1.0.0. Check the logfiles, it may
>> not
>> have loaded properly".
>> If it's the TMS service I need for tile set support in QGIS then I may
>> need
>> to follow this up with either the Geoserver or the GWC guys, because I
>> don't
>> understand what is wrong here.
>> Cheers,
>> Jeremy
>> -----Original Message-----
>> From: Noli Sicad [mailto:nsicad at gmail.com]
>> Sent: Saturday, 17 July 2010 2:05 p.m.
>> To: Jeremy Palmer
>> Cc: qgis-developer at lists.osgeo.org
>> Subject: Re: [Qgis-developer] WMS tileset support
>> Correction.
>> GeoWebCache as the map tile server.
>> Noli
>>> Hi Jeremy,
>>> I think GeoStack has this function - Map tile server
>>> "The "geostack" consists of the following functional parts:
>>> Map tile server that can store pre-rendered map tiles and serve them
>>> up quickly to make maps seems to draw faster. Examples include ArcGIS
>>> Server, MapGuide, Tilecache, GeoWebCache"
>>> http://workshops.opengeo.org/stack-intro/introduction.html
>>> Noli
>>>> I'm trialling the use of Geoserver for serving up images to QGIS
>>>> clients.
>>>> I
>>>> can get WMS to work well. However I was wondering about the QGIS
>>>> support
>>>> for
>>>> tile sets. As far as I can see in the QGIS WMS proveder source code,
>>>> tile
>>>> sets are supported if there is a VendorSpecificCapabilities/TileSet tag
>>>> in
>>>> the get capability request.
>>>> Does any know if you can get Geoserver (or any other open source web
>>>> mapping
>>>> service) to provider this capability?
>>>> Thanks,
>>>> Jeremy Palmer
>>>> Geodetic Surveyor
>>>> National Geodetic Office
>>>> Land Information New Zealand | Toitu te whenua
>>>> 160 Lambton Quay | Private Box 5501 | Wellington 6145
>>>> DDI: 64 (0)4 498 3537 | Fax: 64 (0)4 498 3837 |
>>>> www.linz.govt.nz<http://www.linz.govt.nz>
>>>> ______________________________________________________________________________________________________
>>>> This message contains information, which is confidential and may be
>>>> subject
>>>> to legal privilege.
>>>> If you are not the intended recipient, you must not peruse, use,
>>>> disseminate, distribute or copy this message.
>>>> If you have received this message in error, please notify us
>>>> immediately
>>>> (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original
>>>> message.
>>>> LINZ accepts no responsibility for changes to this email, or for any
>>>> attachments, after its transmission from LINZ.
>>>> Thank you.
>> subject
>> to legal privilege.
>> If you have received this message in error, please notify us immediately
>> message.
>> Thank you.
