[Qgis-developer] Plugin Georeference handle files with existing
	georeferencing information
    Luiz Motta
    motta.luiz at gmail.com
    Sat Jul 17 16:31:50 EDT 2010
Manuel,
I don't find your tickect  #787.
I made few changes in source of Georeference, at, now, the plugin can work
with change of projections (QGIS and Plugin):
1) The input coordinates (populate reference coordinate in table GCP)
are transforms to projection of Plugin.
Can now changes projections in QGIS, this can be useful when need work
different image of  reference.
2) When change projection setting of plugin (EPSG of destination), the
reference coodinate(table of GCP) are change to new
projection.
The path is ticket #2890.
For windows user, can test by DLL:
DOWNLOAD LINK: http://www.hotshare.net/file/276609-8368885b91.html
FILE NAME: georefplugin.zip
FILE SIZE: 250.83 KB
Best Regards,
Luiz Motta
> Hi Luiz,
>>> Add GCP's, in this case, i get the maps coordinate with same projection
>>> of original image (geotif).
> I just realized that you seem to work with GCPS specified in the input
> coordinate system (at least if I understand your workflow correctly, you enter
> seem to enter GCP coordinates in the original coordinate system?).
> Reprojecting the GCPs to another SRS will hopefully be supported soon (see
> #787) from within the plugin.
> cheers,
> 	Manuel
