[Qgis-developer] Plugins with unsatisfied dependencies
Giuseppe Sucameli brush.tyler at gmail.com
Mon Jul 26 18:31:48 EDT 2010
Hi devs,
I found some plugins which throw an error if there are unsatisfied
dependencies.
ThanI investigate the problem and I found that the error is due to
the position of the "import" clause in the __init__.py file.
To resolve it, the "import plugin_name" should be moved into the
classFactory function.
Here an example:
def classFactory(iface):
    from plugin import Plugin
    return Plugin(iface)
I guess this could help to avoid the error installing plugins.
Would be useful if everyone checks his plugins.
In this moment I found Contour and HomeRange_plugin, but could
be more than 2.
Cheers.
Giuseppe Sucameli
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100727/dc78a4a6/attachment.html
