[Qgis-developer] Re: Plugins with unsatisfied dependencies
Lionel Roubeyrie lionel.roubeyrie at gmail.com
Tue Jul 27 03:45:45 EDT 2010
Hi all,
change is made in 0.7.1 for the contour plugin.
Is it possible to hope to see a little change in the plugin system
where plugins devs have the possibility to append a more general
description, not only in a single line? In this way, maybe a simple
text/html file in the plugin package where can be specified
dependencies, special attentions, descriptions, ... will be displayed
by the python plugin installer on a double click or other but before
the installation...
Cheers
2010/7/27 Giuseppe Sucameli <brush.tyler at gmail.com>:
> Hi devs,
> I found some plugins which throw an error if there are unsatisfied
> dependencies.
> ThanI investigate the problem and I found that the error is due to
> the position of the "import" clause in the __init__.py file.
> To resolve it, the "import plugin_name" should be moved into the
> classFactory function.
> Here an example:
> def classFactory(iface):
>     from plugin import Plugin
>     return Plugin(iface)
> I guess this could help to avoid the error installing plugins.
> Would be useful if everyone checks his plugins.
> In this moment I found Contour and HomeRange_plugin, but could
> be more than 2.
> Cheers.
> Giuseppe Sucameli
Lionel Roubeyrie
http://youarealegend.blogspot.com
