[Qgis-developer] possible wms-c bug?
Giovanni Manghi giovanni.manghi at gmail.com
Thu Jul 29 05:40:19 EDT 2010
Olá Duarte,
seems reasonable to file a ticket.
Cheers
-- Giovanni --
On Wed, 2010-07-28 at 13:14 +0100, Duarte Carreira wrote:
> Hello.
> I would like to confirm this is a problem with qgis 1.5 before opening
> a ticket…
> I’m trying to connect to a tilecache service, that has an incorrect
> capabilities doc. Specifically it publicizes wrong OnlineResources
> urls.
> When I connect to this service QGIS shows a window asking if the
> publicized urls should be ignored. I answer yes. From here on QGIS
> does not make any further requests to the server. I checked the
> traffic with a proxy, and the only request that shows up is for the
> capabilities doc.
> I was convinced that QGIS would use the url I entered when creating
> the service, ignoring the caps. doc but still using the original I
> provided.
> So, is this the expected behavior? If so, wouldn’t it be best to just
> tell the user the service is not usable instead of adding the service
> to the map that doesn’t work?
> You can try this with the following url:
> http://mapas.igeo.pt/tilecache/tilecache.py
> I corrected the capabilities doc. You can find it here:
> http://beja019.edia.pt/mapasigeopttilecache.xml
> I just changed all the OnlineResources urls to
> http://mapas.igeo.pt/tilecache/tilecache.py?.
> Thanks,
> Duarte
