[Qgis-developer] Re: Eric4, QScintilla and QGIS
Alex Mandel
tech_dev at wildintellect.com
Fri Jul 30 12:55:37 EDT 2010
On 07/30/2010 09:48 AM, Alex Mandel wrote:
> On 07/30/2010 02:27 AM, dncarreira wrote:
>> Alex, I'll try emailing riverbank.
>> In the meanwhile I tried SPE but couldn't find any qt tools integrated with
>> it. Can you compile .ui to .py or .qrc to .py using the gui?
>> I also found Monkey Studio [1] which does include this kind of integration.
>> It seemed a bit unstable though - still testing... it does integrate very
>> well with Qt designer - you don't even have to open Qt designer separately.
>> Duarte
>> [1] http://monkeystudio.org/ http://monkeystudio.org/
>> Duarte
> No but compiling those is so easy on a command line:
> pyuic4 -o UIexample.py UIexample.ui
> pyrcc4 -o resources_rc.py resources.qrc
> I imagine if you really wanted to integrate it, a quick python script
> calling those commands could be linked to buttons in any editor.
> Besides, I consider auto-completion of code a much more important aspect
> of integration. And Winpdb the debugger that comes with SPE is capable
> of debugging QGIS plugins while they are running in QGIS. Supposedly you
> can do this with ERIC but I haven't figured out how.
> Thanks,
> Alex
As an added note, I keep a command line window open all the time to use
with svn, git, Hg etc since integration of those is never up to my
standards in the IDE either.
Thanks,
Alex
