[Qgis-developer] Re: GdalTools versions
Giuseppe Sucameli
brush.tyler at gmail.com
Fri Jun 4 17:32:15 EDT 2010
Solved... The issue is the one I described in the previous mail.
However, if I install the experimental GdalTools (v.1.2.3) and
I restart QGis as required, the plugin doesn't replace the one in trunk.
Is it the correct behaviour?
If it is, maintaining the experimental one make no sense!
Cheers
On Fri, Jun 4, 2010 at 11:23 PM, Giuseppe Sucameli <brush.tyler at gmail.com>wrote:
> Hi Borys,
> On Fri, Jun 4, 2010 at 9:07 PM, Borys Jurgiel <borysiasty at aster.pl> wrote:
>> Giuseppe pleease... The metadata ;-)
>> 1.2.0 in Trunk and 1.2.1 in the repository, but declared as 1.2.2... :-)
> it's strange... It seems that the autopackaging doesn't works well as
> instead it did. I try to find the issue.
> However, sorry, but it worked well before I changed the version number.
> I think could be a permission issue, because I edited the package and
> the script cannot replace it with the newer.
> Regard.
> Giuseppe Sucameli
Giuseppe Sucameli
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100604/f5b293bb/attachment.html
