[Qgis-developer] Re: GdalTools versions
Martin Dobias
wonder.sk at gmail.com
Mon Jun 7 04:15:11 EDT 2010
On Sat, Jun 5, 2010 at 11:40 AM, Borys Jurgiel <borysiasty at aster.pl> wrote:
>> I guess that the plugin_installer works well. The issue may be in
>> python/utils.py in updateAvailablePlugins function:
>> there are no tests to check if the local plugin is newer then the system
>> one.
> You're right. Martin, seems you've changed the behaviour when moving the code
> to utils.py and now the priority of plugins depends only on python paths
> order.
> Can we at least set fixed path order for 1.5?
Umm... I'm not sure if I understand what's the problem. What else
should affect the priority of plugins? In current semantics, the
locally installed plugins in ~/.qgis are preferred to the global ones
in /usr. So what is the difference from previous implementation in
c++?
Martin
