[Qgis-developer] Re: GdalTools versions
Borys Jurgiel
borysiasty at aster.pl
Mon Jun 7 05:09:21 EDT 2010
Dnia poniedziałek, 7 czerwca 2010 o 10:15:11 Martin Dobias napisał(a):
> On Sat, Jun 5, 2010 at 11:40 AM, Borys Jurgiel <borysiasty at aster.pl> wrote:
> >> I guess that the plugin_installer works well. The issue may be in
> >> python/utils.py in updateAvailablePlugins function:
> >> there are no tests to check if the local plugin is newer then the system
> >> one.
> > You're right. Martin, seems you've changed the behaviour when moving the
> > code to utils.py and now the priority of plugins depends only on python
> > paths order.
> > Can we at least set fixed path order for 1.5?
> Umm... I'm not sure if I understand what's the problem. What else
> should affect the priority of plugins? In current semantics, the
> locally installed plugins in ~/.qgis are preferred to the global ones
> in /usr. So what is the difference from previous implementation in
> c++?
> Martin
Seems they aren't really preffered. It works at mine, but Giuseppe always see
the /usr ones. It's all about python paths, I'm right? I can't see any code
preferring the ~/ ones in Qgis.
Maybe I was wrong thinking that in the previous implementation the two paths
were distinguished.
