[Qgis-developer] GDAL internal libtiff
Tim Sutton
lists at linfiniti.com
Tue Jun 8 17:42:16 EDT 2010
Hi
As far as I know we are not linking against libtiff so I would think
that the libtiff requirement is a cascading dependency.
Regards
Tim
On Tue, Jun 8, 2010 at 11:04 PM, Jamie Adams <jaadfoo at gmail.com> wrote:
> Hello all,
> I've been compiling GDAL 1.7 using the internal tiff support (for BigTiff).
> QGIS 1.4 still requires the system libtiff to be installed, which is an
> older version from what GDAL is using. Does this cause any conflicts /
> instability? I occasionally get crashes when viewing large GeoTiffs (with
> pyramids), but haven't spent much time debugging. I ask because I'm in the
> process of setting up several new machines and I'd like everything as stable
> as possible, yet keep the steps simple. I'll compile libtiff 4.0 if needed,
> but only if it makes a difference.
> Thanks,
> Jamie
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
