[Qgis-developer] QGIS Development Version - Error Trying to Open GeoTIFF
Bruce, Bob (CON) Bob.Bruce at gov.mb.ca
Thu Jun 10 14:00:58 EDT 2010
Yesterday I downloaded the latest development version of OSGEO4W QGIS
(1.5.0 code version 13686) and tried opening a GeoTIFF SPOT image and
got the error message:
I confirmed that I could open the image in QGIS 1.1 and 1.3 so it looks
like the problem is with the development version. Here is the
information about the image from GDALINFO:
E:\>gdalinfo SPOT_imagery_mosaic_misty_lake_mb.tif
Driver: GTiff/GeoTIFF
Files: SPOT_imagery_mosaic_misty_lake_mb.tif
Size is 11659, 30731
Coordinate System is:
PROJCS["NAD83 / UTM zone 14N",
    GEOGCS["NAD83",
        DATUM["North_American_Datum_1983",
            SPHEROID["GRS 1980",6378137,298.2572221010002,
                AUTHORITY["EPSG","7019"]],
            AUTHORITY["EPSG","6269"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4269"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",-99],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","26914"]]
Origin = (325435.000000000000000,6570672.500000000000000)
Pixel Size = (2.500000000000000,-2.500000000000000)
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (  325435.000, 6570672.500)
Lower Left  (  325435.000, 6493845.000)
Upper Right (  354582.500, 6570672.500)
Lower Right (  354582.500, 6493845.000)
Center      (  340008.750, 6532258.750)
Band 1 Block=11659x1 Type=Byte, ColorInterp=Gray
Could someone verify that this is a problem with this version of QGIS?
Thanks,
	 Bob Bruce
**  Bob Bruce, FEC, P.Eng.     Geomatics Support Engineer
**  Bob.Bruce at gov.mb.ca        Manitoba Geomatics/Remote Sensing Branch,
**  work # (204) 945-6636      1007 Century Street,
**  FAX  # (204) 945-1365      Winnipeg, Manitoba, Canada, R3H 0W4
**  The Manitoba Centre for:
**   Cadastral & Topographical Mapping, and Remote Sensing
**   See us on the Web at: http://www.gov.mb.ca/conservation/geomatics/
**        Check out our digital maps at: http://mlidata.gov.mb.ca/WPMLI
**                 and: https://mli2.gov.mb.ca/
