[Qgis-developer] SDA4PP issues
Paolo Cavallini
cavallini at faunalia.it
Fri Jun 11 09:55:53 EDT 2010
Hi all.
Various issues:
http://ggit.metu.edu.tr/~volkan/
is down
# kernel analysis crash with:
ReadQGISLayer | createOutputDir | outputpathdir = "/tmp/SDA4PP/"
The program 'R' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadMatch (invalid parameter attributes)'.
(Details: serial 57994260 error_code 8 request_code 42 minor_code 0)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error() function.)
qgis.bin: RelateComputer.cpp:251: void
geos::operation::relate::RelateComputer::computeIntersectionNodes(int):
Asserzione `dynamic_cast<RelateNode*>(nodes.addNode(ei->coord))' fallita.
# kriging returns an error
Errore durante l'esecuzione di codice Python:
File "/home/paolo/.qgis/python/plugins/SDA4PP/kriging.py", line 126, in
runClose
sda4ppRoptions.closeRplot(self.R)
File "/home/paolo/.qgis/python/plugins/SDA4PP/sda4ppRoptions.py", line 135,
in closeRplot
for i in range(int(str(n[0]))):
TypeError: 'RObject' object does not support indexing
All the best.
http://faunalia.it/pc
