[Qgis-developer] SDA4PP issues
Volkan Kepoglu
vkepoglu at gmail.com
Mon Jun 14 07:55:32 EDT 2010
On Fri, Jun 11, 2010 at 4:55 PM, Paolo Cavallini <cavallini at faunalia.it>wrote:
> Hi all.
> Various issues:
> http://ggit.metu.edu.tr/~volkan/
> is down
the server is down and I'll fix it as soon as possible.
> # kernel analysis crash with:
> ReadQGISLayer | createOutputDir | outputpathdir = "/tmp/SDA4PP/"
> The program 'R' received an X Window System error.
> This probably reflects a bug in the program.
> The error was 'BadMatch (invalid parameter attributes)'.
> (Details: serial 57994260 error_code 8 request_code 42 minor_code 0)
> (Note to programmers: normally, X errors are reported asynchronously;
> that is, you will receive the error a while after causing it.
> To debug your program, run it with the --sync command line
> option to change this behavior. You can then get a meaningful
> backtrace from your debugger if you break on the gdk_x_error() function.)
> qgis.bin: RelateComputer.cpp:251: void
> geos::operation::relate::RelateComputer::computeIntersectionNodes(int):
> Asserzione `dynamic_cast<RelateNode*>(nodes.addNode(ei->coord))' fallita.
> # kriging returns an error
> Errore durante l'esecuzione di codice Python:
> Traceback (most recent call last):
> File "/home/paolo/.qgis/python/plugins/SDA4PP/kriging.py", line 126, in
> runClose
> sda4ppRoptions.closeRplot(self.R)
> File "/home/paolo/.qgis/python/plugins/SDA4PP/sda4ppRoptions.py", line 135,
> in closeRplot
> for i in range(int(str(n[0]))):
> TypeError: 'RObject' object does not support indexing
> All the best.
> http://faunalia.it/pc
> Qgis-developer mailing list
Regards,
Volkan Osman Kepoglu
PhD Candidate
GGIT Department in METU,
http:/ggit.metu.edu.tr
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100614/67755cda/attachment.html
