[Qgis-developer] SDA4PP issues
Volkan Kepoglu
vkepoglu at gmail.com
Fri Jun 18 05:13:57 EDT 2010
On Mon, Jun 14, 2010 at 2:55 PM, Volkan Kepoglu <vkepoglu at gmail.com> wrote:
> On Fri, Jun 11, 2010 at 4:55 PM, Paolo Cavallini <cavallini at faunalia.it>wrote:
>> Hi all.
>> Various issues:
>> http://ggit.metu.edu.tr/~volkan/
>> is down
> the server is down and I'll fix it as soon as possible.
the server is fixed now.
>> # kernel analysis crash with:
>> ReadQGISLayer | createOutputDir | outputpathdir = "/tmp/SDA4PP/"
>> The program 'R' received an X Window System error.
>> This probably reflects a bug in the program.
>> The error was 'BadMatch (invalid parameter attributes)'.
>> (Details: serial 57994260 error_code 8 request_code 42 minor_code 0)
>> (Note to programmers: normally, X errors are reported asynchronously;
>> that is, you will receive the error a while after causing it.
>> To debug your program, run it with the --sync command line
>> option to change this behavior. You can then get a meaningful
>> backtrace from your debugger if you break on the gdk_x_error() function.)
>> qgis.bin: RelateComputer.cpp:251: void
>> geos::operation::relate::RelateComputer::computeIntersectionNodes(int):
>> Asserzione `dynamic_cast<RelateNode*>(nodes.addNode(ei->coord))' fallita.
No idea, I have never seen such an error in my life.
> # kriging returns an error
>> Errore durante l'esecuzione di codice Python:
>> Traceback (most recent call last):
>> File "/home/paolo/.qgis/python/plugins/SDA4PP/kriging.py", line 126, in
>> runClose
>> sda4ppRoptions.closeRplot(self.R)
>> File "/home/paolo/.qgis/python/plugins/SDA4PP/sda4ppRoptions.py", line
>> 135,
>> in closeRplot
>> for i in range(int(str(n[0]))):
>> TypeError: 'RObject' object does not support indexing
when this error occurs? could you give more information about the error how
is happing?
Does this error occur also for all tools while close button is clicked or
just occurs for only kriging tools?
>> All the best.
>> http://faunalia.it/pc
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Regards,
> Volkan Osman Kepoglu
> PhD Candidate
> GGIT Department in METU,
> http:/ggit.metu.edu.tr
Regards,
PhD Candidate
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100618/07154ac3/attachment-0001.html
