[Qgis-developer] QGIS plugin repo [was: Value Tool]
Alex Mandel
tech_dev at wildintellect.com
Sun Jun 13 18:19:09 EDT 2010
On 06/13/2010 03:02 PM, Borys Jurgiel wrote:
>> I've brought this up several times in the past too. Something similar to
>> http://trac-hacks.org would be great, especially if we can integrate it
>> with pyqgis.org so that you could click through the web to release a new
>> version to the xml repos.
> Of course, it should be integrated. But it must be disputed how to trigger the
> release? Also, how to maintain multiple versions? E.g. one stable and one
> development. Should they be maintained in separate directories? If so, a
> synchronization tool would be nice... A lot of questions, but I believe
> there's a good basis in the end :)
>> I'll look into options, that would allow plugin authors or qgis devs to
>> grant access to plugins in an easy manner (through the web).
> It's essential :)
I think I found the answer http://trac-hacks.org/wiki/SvnAuthzAdminPlugin
Alex
