[Qgis-developer] Testsuite
Volker Fröhlich volker27 at gmx.at
Sun Jun 20 18:38:07 EDT 2010
Thank you, Martin!
Yes, I realized you need it installed, which is a pity, because you can't use
it before packaging to RPM. I also had the experience that some tests failed,
others didn't.
Are the tests still maintained?
Volker
Am Sonntag 20 Juni 2010, 13:36:44 schrieben Sie:
> Hi Volker
> 2010/6/13 Volker Fröhlich <volker27 at gmx.at>:
> > Or does it work in SVN, if that is easier to answer?
> > Am Freitag 11 Juni 2010, 22:19:01 schrieb Volker Fröhlich:
> >> Hello!
> >> Does 1.4.0's testsuite work correctly?
> Not all tests pass on my computer (actually 7 out of 15 fail).
> If you run 'make test' and all tests just immediately fail, make sure
> you've done 'make install' before to ensure that QGIS installation is
> in place where the tests will expect it. Second, you will probably
> need to set path to QGIS libraries directory if you install to
> non-standard path (use environment variable PATH on windows or
> LD_LIBRARY_PATH on linux).
> Regards
> Martin
