[Qgis-developer] Photo2Shape
Craig Leat craig.leat at gmail.com
Thu Jun 24 08:29:42 EDT 2010
Some comments after using Photo2Shape version 0.1.14
1. The error message that appears when no co-ordinates were found says
"The following files does added ...". This could be "The following
files were not added ...".
2. On the above mentioned message window the tick box "Show this
message again" does not work. Unticked the message still appears.
3. If no geotagged photos are found an empty shapefile is created.
4. The title on the main dialog box says "Images to shapefile".
Perhaps this should be "Photo2Shape"?
5. On Ubuntu the two browse buttons display file selection dialogs
with different styles. The photo selection dialog looks like Nautilus,
but the shapefile selection dialog looks different.
6. The qml file contains Russian text for the default label.
7. The camera symbols do not turn yellow when selected on the map canvas.
8. The camera symbols are replaced with dots if the symbology is
changed. Try adding labels for example.
Besides these minor issues the plugin works very well and I
successfully processed a few hundred photos. Thank you :)
Craig
