[Qgis-developer] Photo2Shape
Alexander Bruy alexander.bruy at gmail.com
Mon Jun 28 12:50:01 EDT 2010
Thanks for your feedback, Craig!
On Thu, 24 Jun 2010 14:29:42 +0200
Craig Leat <craig.leat at gmail.com> wrote:
> 1. The error message that appears when no co-ordinates were found says
> "The following files does added ...". This could be "The following
> files were not added ...".
Fixed in 0.1.15
> 2. On the above mentioned message window the tick box "Show this
> message again" does not work. Unticked the message still appears.
> 3. If no geotagged photos are found an empty shapefile is created.
> 4. The title on the main dialog box says "Images to shapefile".
> Perhaps this should be "Photo2Shape"?
Both fixed in 0.1.15. If no geotagged photos are found - there is no
output shapefile created. Title of the main dialog fixed.
> 5. On Ubuntu the two browse buttons display file selection dialogs
> with different styles. The photo selection dialog looks like Nautilus,
> but the shapefile selection dialog looks different.
For folder selection plugin call standard open dialog. For shapefile
selection used special dialog with additional codepage selector. Same
dialog used by QGIS when you add an shapefile.
> 6. The qml file contains Russian text for the default label.
Fixed in 0.1.15, now default label in English
> 7. The camera symbols do not turn yellow when selected on the map canvas.
This is not a plugin issue. Point features with SVG markers are not
highlighted when they are selected.
> 8. The camera symbols are replaced with dots if the symbology is
> changed. Try adding labels for example.
I'll look on this.
Alexander Bruy
