[Qgis-developer] mapserver export plugin bug
Richard Duivenvoorde rdmailings at duif.net
Mon Jun 28 17:44:24 EDT 2010
Carson Farmer wrote:
> Potential small bug found during a training course:
> If there are two versions of the same PostGIS layer open and
> symbolised, one with a WHERE clause, and the other without (i.e. one
> should have a filter and one shouldn't), when exporting to a map file
> (layers only), both layers appear to have the filter applied. Can
> anyone else confirm this? We're using QGIS 1.4 with latest mapserver
> export plugin, using local postgis server....
> Let me know if you need any further info...
> Carson
Hi Carson,
I can confirm the bug. It is not a typical postgis layer bug. It's the
fact that the layers have the same (display)name in qgis, which are then
used to store and retrieve them from a dictionary.
Besides this being a bug, it's also wrong because WMS-layers should have
unique names anyway.
Tried to fix it now, but ... failed
Please file a bug.
Regards,
