[Qgis-developer] set plugin enabled by default
Stefan Kiefer st_kiefer at web.de
Mon Mar 1 07:24:56 EST 2010
thanks a lot for the immediate answers. What you all say is true for
plugins installed from a respository, resp. with the plugin-installer.
What I need is when I put a custom plugin (one I made by myself) to the
qgis/python/plugins-folder. Hence, if I do that the plugin can be
activated in the pluginmanager, but is not activated by default.
The way is that one get an installer (in this case a selfextractable
file) and the plugin gets copied to the plugins folder. Unfortunately
then the user is forced to search in the pluginmanager for the new
plugin to activate it. I need to realize this more comfortable, i.e.
without confronting the user to open the plugin installer nor the
manager ...
thanks for your efforts
stefan
> Hi,
> as far as I can see since qgis 1.4 python plugins are immediately
> activated after installation.
> cheers
> -- Giovanni --
> On Fri, 2010-02-26 at 19:48 +0100, Stefan Kiefer wrote:
>> Hi there,
>> does someone knows if there is a way to set a plugin enabled by default.
>> My trouble is: when the Plugin gets installed it should be visible to
>> the user after startup of Qgis. The user should not be forced to open
>> the plugs menu and search for the plugin and activate it.
>> Is there any way to perform this, probably by modifying the default
>> plugins (ftools or plugin_installer). It must work for standard Qgis
>> installations, without changing the source code (modifying the python
>> code is also not what I really need, but could be a workaround).
>> Maybe there is a possibility to get the installed plugins and activate
>> the one needed?
>> thanks for your help
>> cheers
>> Stefan
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
