[Qgis-developer] editing nodes
Giovanni Manghi giovanni.manghi at gmail.com
Mon Mar 15 05:53:31 EDT 2010
On Mon, 2010-03-15 at 11:47 +0200, Micha Silver wrote:
> I find that the new arrangement for editing nodes in a polygon or line
> feature is more difficult that before. Previously there was a set a
> buttons for moving nodes, deleting nodes, etc. Now there's the single
> "node tool" button. When clicking on a node, all nodes become red
> squares, and it's not clear how to select/move/delete a single node.  A
> second click seems to always select (change to blue color) a line
> *segment*, i.e. two nodes. Then any action - moving, etc - applies to
> both nodes.
> Am I missing something? How do I select a single node?
after having all nodes red, if you click once on a node this become
selected (blue) (if you then press ctrl you can selected multiple
nodes). If you click once between two nodes the segment between the
nodes is select.
It also took to me a couple of days to get used when it was introduced.
Actually new qgis users found the node tool pretty good.
cheers
-- Giovanni --
