[Qgis-developer] crash when loading layers
Paolo Cavallini cavallini at faunalia.it
Sun Mar 21 16:58:09 EDT 2010
Apparently, deactivating the autosave plugin solves the problem.
Could the plugin author please check?
All the best.
Hi all.
I'm getting frequent crashes when loading rasters and vectors:
Warning: Object::connect: No such signal
QgsRasterDataProvider::statusChanged( QString ) in
/home/paolo/build/qgis_unstable/src/core/raster/qgsrasterlayer.cpp:228
allfiles:
/home/paolo/Desktop/Dati_corso_QGIS/qgs-save-91.qgs,/home/paolo/Desktop/Dati_corso_QGIS/qgs-save-94.qgs,/home/paolo/Desktop/Dati_corso_QGIS/qgs-save-93.qgs,/home/paolo/Desktop/Dati_corso_QGIS/qgs-save-95.qgs,/home/paolo/Desktop/Dati_corso_QGIS/qgs-save-90.qgs,/home/paolo/Desktop/Dati_corso_QGIS/qgs-save-89.qgs,/home/paolo/Desktop/Dati_corso_QGIS/qgs-save-92.qgs
fcodes has length 7 and number = 7
removes:/home/paolo/Desktop/Dati_corso_QGIS/qgs-save-89.qgs
fails:
Segmentation fault
Furthermore, I also got a segfault with:
Warning: QPainterPath::arcTo: Adding arc where a parameter is NaN,
results are undefined
Anyone has the same problem? Can we try to debug it together?
All the best.
http://www.faunalia.it/pc
