[Qgis-developer] plugin's menu organization
Andreas Neumann a.neumann at carto.net
Mon Mar 29 02:41:38 EDT 2010
Hi all,
For the issue on how to find the plugin: one option would be to have a
mini-documentation popping up after the plugin install that indicates:
* where to find the plugin (menu, toolbar)
* quick info how to use it
* Link to webpage with full documentation.
This mini documentation could be part of the plugins.xml file of the
repository.
What do you think?
Andreas
On Sun, March 28, 2010 10:45 pm, Borys Jurgiel wrote:
>> Completely seperate plugin section, otherwise when you turn on a plugin
>> you'll have no idea where it is. An exception to this would be if the
>> Manage plugins where you go to activate them had tabs with the same
>> names, that would clearly indicate where you should find the plugin once
>> it's turned on.
> Thanks. So clear categorization withing the existing plugin menu seems
> best
> for a start.
> Qgis-developer mailing list
Andreas Neumann
http://www.carto.net/neumann/
http://www.svgopen.org/
