[Qgis-developer] plugin's menu organization
Borys Jurgiel
borysiasty at aster.pl
Sun Mar 28 16:45:07 EDT 2010
> Completely seperate plugin section, otherwise when you turn on a plugin
> you'll have no idea where it is. An exception to this would be if the
> Manage plugins where you go to activate them had tabs with the same
> names, that would clearly indicate where you should find the plugin once
> it's turned on.
Thanks. So clear categorization withing the existing plugin menu seems best
for a start.
