[Qgis-developer] Re: Symbol pattern scaling issues: raster versus
vector pdf
Marco Hugentobler
marco at hugis.net
Tue Mar 30 15:01:03 EDT 2010
Hi John
The vector scaling issue in (vector) pdf is a bug in Qts pdf paint engine:
http://bugreports.qt.nokia.com/browse/QTBUG-5114
But now there is a patch for it in the qt bugtracker. So hopefully it is fixed
in the newer versions (or you could apply the small modification in the ticket
if you have a 4.5).
Regards,
Marco
Am Dienstag, 30. März 2010 17.59:59 schrieb John C. Tull:
> Hi Marco,
> I assume you saw the bug I filed the other day on this:
> https://trac.osgeo.org/qgis/ticket/2598
> I wanted to follow up with you because exporting to vectorized pdf seems to
> be a possible workaround for the strange polygon fill/shading bug that
> occasionally crops up for me (recall our communication and the screenshots
> from the hackfest). For projects that have the fill problem, exporting to
> pdf as a vectorized pdf file avoids the fill problem. Unfortunately, the
> issue with symbol fill pattern differences arises, as described in the bug
> report.
> I'm hoping there is a simple solution to this problem. Otherwise, I am at a
> loss for creating printable, high-quality maps in qgis for many of my
> projects.
> Regards,
> John
Dr. Marco Hugentobler
HUGIS GmbH
Webereistr. 66
CH-8134 Adliswil
marco at hugis.net
www.hugis.net
Technical Advisor QGIS Project Steering Committee
