[Qgis-developer] GoogleLayers
Ivan Mincik
ivan.mincik at gista.sk
Thu May 6 08:45:39 EDT 2010
> Hi,
> QGIS-1-4-0
> test 1:
> - fresh qgis start (no project loaded, on-the-fly transformation is OFF)
> - load your shape
> - press gmap plugin button
> - aligment is perfect
> test 2:
> - set project CRS to 900913
> - enable on-the-fly transformation
> - load your shape
> test 3:
> - set project CRS to 32632
> - load your shape
> - aligment is wrong
> is this the expected behavior?
> shouldn't qgis reproject the raster ?
You should always use 900913 CRS for Your project and reproject all data in to this projection.
Ivan Mincik
Gista s.r.o.
Name: not available
Desc: This is a digitally signed message part.
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100506/808f088b/attachment.bin
