[Qgis-developer] GoogleLayers
Alessandro Pasotti
apasotti at gmail.com
Thu May 6 07:27:44 EDT 2010
2010/5/6 Ivan Mincik <ivan.mincik at gista.sk>
> > > > Done.
> > > > v0.6 - introduces Ivan's fix
> > > > v0.6.1 - fixes icon resource name mismatch to icon.png everywhere
> > > Has somebody else tested if it is working ? Both Linux and Win ?
> > > Ivan Mincik
> > > Gista s.r.o.
> > Hi,
> > I'm testing on Linux (ubuntu, latest), it's running fine except that I
> > couldn't align the gmap layer with my ED50_UTM_32_N shapefile map.
> > On-the-fly projection is on and the shapefile layer has its CRS set.
> > any hint ?
> Check if Your project is correctly using Google 900913 CRS and Your data
> is also in correct projection.
Setting project projection to the custom projection created by the plugin
(which is in fact 900913) aligns perfectly.
What is still unclear to me is why it happens: shouldn't the layer's CRS be
sufficient to have a correct alignment ?
In other words, if I have 2 layers (shapefile=23032 and gmap=900913) with
CRS correctly set, the canvas should align independently from project's CRS,
am I wrong ?
Alessandro Pasotti
w3: www.itopen.it
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100506/6cdad902/attachment.html
