[Qgis-developer] GoogleLayers
Ivan Mincik
ivan.mincik at gista.sk
Fri May 7 09:11:53 EDT 2010
On Friday 07 May 2010, Ricardo Filipe Soares Garcia da wrote:
> Hello
> I am trying to test this plugin out on Ubuntu Lucid. I have installed
> it from the plugin manager. However I haven't got any Google Mercator
> entry in the CRS menu. I've tried to search for EPSG 900913 and also
> by name and it doens't show up. In case it is relevant I am using Qgis
> 1.4 from the ubuntugis-unstable PPA.
> On Fri, May 7, 2010 at 8:23 AM, Ivan Mincik <ivan.mincik at gista.sk> wrote:
> > I have installed new Windows computer for testing plugin. Test was
> > without any problem (QGIS 1.4)
> > Ivan Mincik
> > Gista s.r.o.
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
You can add following lines to '/usr/share/proj/epsg' to add Google projection (be carefull, projection definition must
be at one line):
# Google projection
<900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null
+no_defs <>
Ivan Mincik
Gista s.r.o.
Name: not available
Desc: This is a digitally signed message part.
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100507/9b9f816d/attachment.bin
