[Qgis-developer] Re: [Qgis-user] Updated GdalTools
Ivan Mincik
ivan.mincik at gmail.com
Sun May 16 17:04:26 EDT 2010
On Sun, May 16, 2010 at 10:58 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Hi all.
> GdalTools (AKA Raster Tools) as of v.1.1.15 has undergone some major improvements:
> - more than a command can be executed simultaneously
> - in the meantime, QGIS can still be used (useful for long-running commands)
> - there are 2 more notices for the user:
> . one that warns if one is trying to close a running tool
> . one at the completion of the execution
> When a long running command ends, the second message pops up in the foreground.
> https://trac.faunalia.it/GdalTools-plugin/
Hi, just tested. It looks fine. Nice improvements. I have installed it
manually, since it is not currently available from You repo.
Ivan
