[Qgis-developer] Re: [Qgis-user] Updated GdalTools
Giuseppe Sucameli brush.tyler at gmail.com
Sun May 16 17:45:48 EDT 2010
Hi Ivan,
On Sun, May 16, 2010 at 11:04 PM, Ivan Mincik <ivan.mincik at gmail.com> wrote:
> On Sun, May 16, 2010 at 10:58 AM, Paolo Cavallini <cavallini at faunalia.it>
> wrote:
> > Hi all.
> > GdalTools (AKA Raster Tools) as of v.1.1.15 has undergone some major
> improvements:
> > - more than a command can be executed simultaneously
> > - in the meantime, QGIS can still be used (useful for long-running
> commands)
> > - there are 2 more notices for the user:
> > . one that warns if one is trying to close a running tool
> > . one at the completion of the execution
> > When a long running command ends, the second message pops up in the
> foreground.
> > https://trac.faunalia.it/GdalTools-plugin/
> Hi, just tested. It looks fine. Nice improvements. I have installed it
> manually, since it is not currently available from You repo.
in the Faunalia repository there are 2 versions of GdalTools:
v.1.1.9, the stable one
v.1.1.15, the experimental one (this contains the improvements)
So you have to enable experimental plugins in the plugins installer
to update the installed version.
Greets.
Giuseppe Sucameli
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100516/d987f031/attachment.html
