[Qgis-developer] problems with SDA4PP plugin
Giovanni Manghi
giovanni.manghi at gmail.com
Wed May 19 06:30:50 EDT 2010
Hi Volkan,
very nice the idea to add the R package installer in the plugin.
I'm noticing the following:
*) the R package installer does not seems to "see" that the necessary
packages were already installed (using the R console).
*) after installing the packages, with the R package installer, it keeps
saying that iplots and rggobi are not installed (under Seven) or that
rgdal and rggobi are not installed (under xp). Trying install again the
"missing" packages (even after removing the package folders in the R
library folder) does not seems to help.
cheers
-- Giovanni --
On Tue, 2010-05-18 at 15:12 +0300, Volkan Kepoglu wrote:
> SDA4PP is revised to 0.181 and both problem is solved;
> loading R packages at the start up is changed. should be, now, more
> faster.
> tested under osgeow and the plugin is working.
> Be sure that environmental variables should be set.
> I am tested with R 2.10.1, so that, set two variables;
> add path variable: C:\Program Files\R\R-2.10.1\bin
> and set R_HOME = C:\Program Files\R\R-2.10.1 in the windows.
> Volkan
> On Mon, May 17, 2010 at 4:57 PM, Giovanni Manghi
> <giovanni.manghi at gmail.com> wrote:
> Hi,
> > SDA4PP uses only rpy2. I never tried under osgeo4w. But
> theoretically,
> > as Carson said, the plugin should also run under osgeo4w, if
> required
> > R packages are installed and the path of R is defined
> correctly.
> > if it is tried, is there any error?
> I tried but it doesn't seems to work. It always says that
> rgdal is
> missing, but R/rpy2/rgdal/etc. are correctly installed as the
> Home Range
> plugin (that uses R/rpy2/rgdal/etc.) is working fine.
> cheers
> -- Giovanni --
> Regards,
> Volkan Osman Kepoglu
> PhD Candidate
> GGIT Department in METU,
> http:/ggit.metu.edu.tr
