[Qgis-developer] problems with SDA4PP plugin
Volkan Kepoglu
vkepoglu at gmail.com
Tue May 18 10:00:09 EDT 2010
revision should be 0.182
Volkan
On Tue, May 18, 2010 at 3:12 PM, Volkan Kepoglu <vkepoglu at gmail.com> wrote:
> SDA4PP is revised to 0.181 and both problem is solved;
> loading R packages at the start up is changed. should be, now, more faster.
> tested under osgeow and the plugin is working.
> Be sure that environmental variables should be set.
> I am tested with R 2.10.1, so that, set two variables;
> add path variable: C:\Program Files\R\R-2.10.1\bin
> and set R_HOME = C:\Program Files\R\R-2.10.1 in the windows.
> Volkan
> On Mon, May 17, 2010 at 4:57 PM, Giovanni Manghi <
> giovanni.manghi at gmail.com> wrote:
>> Hi,
>> > SDA4PP uses only rpy2. I never tried under osgeo4w. But theoretically,
>> > as Carson said, the plugin should also run under osgeo4w, if required
>> > R packages are installed and the path of R is defined correctly.
>> > if it is tried, is there any error?
>> I tried but it doesn't seems to work. It always says that rgdal is
>> missing, but R/rpy2/rgdal/etc. are correctly installed as the Home Range
>> plugin (that uses R/rpy2/rgdal/etc.) is working fine.
>> cheers
>> -- Giovanni --
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100518/a7086379/attachment.html
