[Qgis-developer] problems with SDA4PP plugin
Giovanni Manghi giovanni.manghi at gmail.com
Wed May 19 08:48:18 EDT 2010
> I'm noticing the following:
> *) the R package installer does not seems to "see" that the necessary
> packages were already installed (using the R console).
> *) after installing the packages, with the R package installer, it keeps
> saying that iplots and rggobi are not installed (under Seven) or that
> rgdal and rggobi are not installed (under xp).  Trying install again the
> "missing" packages (even after removing the package folders in the R
> library folder) does not seems to help.
I cleaned the system, reinstalled R and QGIS and now it seems to work
all fine. So it was a problem not related to the plugin.
Sorry for the noise.
cheers
-- Giovanni --
