[Qgis-developer] Re: problems with SDA4PP plugin
Hugo Santos
ulmi.giga at gmail.com
Mon May 24 09:27:38 EDT 2010
i'm having kind of the same problem that Giovanni had;
Giovanni Manghi wrote:
>> I'm noticing the following:
>> *) the R package installer does not seems to "see" that the necessary
>> packages were already installed (using the R console).
>> *) after installing the packages, with the R package installer, it keeps
>> saying that iplots and rggobi are not installed (under Seven) or that
>> rgdal and rggobi are not installed (under xp). Trying install again the
>> "missing" packages (even after removing the package folders in the R
>> library folder) does not seems to help.
But i cleaned out my system, reinstalled everthing but the problem persists!
>From what i understand it has something to do with the system variables or
the Renviron.site file, but i changed and mess with it and solved the
problem from the other packages with the exception of rgdal and rggobi.
If someone could lend any help...thx in advance
Cheers,
Hugo Santos
Open Source GIS Junkie
http://twitter.com/ulmi http://twitter.com/ulmi
View this message in context: http://osgeo-org.1803224.n2.nabble.com/problems-with-SDA4PP-plugin-tp5058086p5093838.html
Sent from the qgis-developer mailing list archive at Nabble.com.
