[Qgis-developer] Re: problems with SDA4PP plugin
Giovanni Manghi
giovanni.manghi at gmail.com
Mon May 24 12:57:54 EDT 2010
Hi Hugo,
in my case I removed qgis (all the osgeo4w installation), R, and the
folders where R/QGIS store libraries/plugins. Then I scanned the system
with CCleaner to remove registry errors.
After the re-installation of all the components all is working fine.
To notice that under Seven (english locale) the R console seems to want
to install the libraries into a folder called
'C:\Users\username\Documents/R/win-library/2.11'
but that actually doesn't exist, because is ""My Documents" instead.
So the libraries in 'C:\Users\username\My Documents/R/win-library/2.11'
seem to be ignored by qgis plugins.
SDA4PP install the libraries in another location, that it good
C:\Users\username\R\win-library\2.11
cheers
-- Giovanni --
On Mon, 2010-05-24 at 06:27 -0700, Hugo Santos wrote:
> Hi,
> i'm having kind of the same problem that Giovanni had;
> Giovanni Manghi wrote:
> >> I'm noticing the following:
> >> *) the R package installer does not seems to "see" that the necessary
> >> packages were already installed (using the R console).
> >> *) after installing the packages, with the R package installer, it keeps
> >> saying that iplots and rggobi are not installed (under Seven) or that
> >> rgdal and rggobi are not installed (under xp). Trying install again the
> >> "missing" packages (even after removing the package folders in the R
> >> library folder) does not seems to help.
> But i cleaned out my system, reinstalled everthing but the problem persists!
> >From what i understand it has something to do with the system variables or
> the Renviron.site file, but i changed and mess with it and solved the
> problem from the other packages with the exception of rgdal and rggobi.
> If someone could lend any help...thx in advance
> Cheers,
> Hugo Santos
> Open Source GIS Junkie
> http://twitter.com/ulmi http://twitter.com/ulmi
