[Qgis-developer] Re: problems with SDA4PP plugin
Volkan Kepoglu
vkepoglu at gmail.com
Tue May 25 02:20:49 EDT 2010
My environment is;
osgeow in the win XP under vmware workstation 7.0
qgis 1.5.0 r13551m
R 2.10.1
all r packages are installed under: C:\Program Files\R\R-2.10.1\library
> sessionInfo()
R version 2.10.1 (2009-12-14)
i386-pc-mingw32
locale:
[1] LC_COLLATE=English_United States.1252
[2] LC_CTYPE=English_United States.1252
[3] LC_MONETARY=English_United States.1252
[4] LC_NUMERIC=C
[5] LC_TIME=English_United States.1252
attached base packages:
[1] stats graphics grDevices utils datasets methods base
python 2.5.2
rpy2 2.0.3
environment variables:
"R_HOME" C:\Program Files\R\R-2.10.1
"Path" should also have this: C:\Program Files\R\R-2.10.1\bin
but not yet installed under Win 7.
On Mon, May 24, 2010 at 7:57 PM, Giovanni Manghi
<giovanni.manghi at gmail.com>wrote:
> Hi Hugo,
> in my case I removed qgis (all the osgeo4w installation), R, and the
> folders where R/QGIS store libraries/plugins. Then I scanned the system
> with CCleaner to remove registry errors.
> After the re-installation of all the components all is working fine.
> To notice that under Seven (english locale) the R console seems to want
> to install the libraries into a folder called
> 'C:\Users\username\Documents/R/win-library/2.11'
> but that actually doesn't exist, because is ""My Documents" instead.
> So the libraries in 'C:\Users\username\My Documents/R/win-library/2.11'
> seem to be ignored by qgis plugins.
> SDA4PP install the libraries in another location, that it good
> C:\Users\username\R\win-library\2.11
> cheers
> -- Giovanni --
> On Mon, 2010-05-24 at 06:27 -0700, Hugo Santos wrote:
> > Hi,
> > i'm having kind of the same problem that Giovanni had;
> > Giovanni Manghi wrote:
> > >> I'm noticing the following:
> > >> *) the R package installer does not seems to "see" that the necessary
> > >> packages were already installed (using the R console).
> > >> *) after installing the packages, with the R package installer, it
> keeps
> > >> saying that iplots and rggobi are not installed (under Seven) or that
> > >> rgdal and rggobi are not installed (under xp). Trying install again
> the
> > >> "missing" packages (even after removing the package folders in the R
> > >> library folder) does not seems to help.
> > But i cleaned out my system, reinstalled everthing but the problem
> persists!
> > >From what i understand it has something to do with the system variables
> or
> > the Renviron.site file, but i changed and mess with it and solved the
> > problem from the other packages with the exception of rgdal and rggobi.
> > If someone could lend any help...thx in advance
> > Cheers,
> > Hugo Santos
> > Open Source GIS Junkie
> > http://twitter.com/ulmi http://twitter.com/ulmi
> Qgis-developer mailing list
Regards,
Volkan Osman Kepoglu
PhD Candidate
GGIT Department in METU,
http:/ggit.metu.edu.tr
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100525/b699eeae/attachment.html
